What the hell Nitto?
Old Jul 15, 2011 | 11:58 AM
SAchris's Avatar
Default What the hell Nitto?
I bought a set of NT05s for the Z28 not even a month ago. I took them on a road trip so they have higher than normal miles on them for only being three weeks old. I estimate they have around 2300 miles on them. They are mounted on American Racing Torq Thrust M wheels; 17x9 front 17x10.5 rear. I have 275s up front and 315s out back. Just your normal set up. I purchased them and had them mounted, balanced, etc. at Discount tire.
This happened yesterday cruising at 75mph down the highway. It is the driver side rear 315.
I have yet to take these to the track. It does not inspire a whole lot of confidence...
Only the outside separated, the inside is still intact.
Let me know if you guys want to see more pictures.
Chris
Old Jul 15, 2011 | 12:02 PM
Platinum WS6's Avatar
you definitely changed my mind on those! I will stick with the 555r's
Old Jul 15, 2011 | 12:25 PM
bobbyd's Avatar
woah that sux man. is it me or does the tires look bald? also check the date of the tire did they sell you a old tire? are they going to replace it?
glar you're ok and glad the car is also good.
Old Jul 15, 2011 | 12:31 PM
Stippy17's Avatar
I'm in the tire business.
Id like to see more pics especially close up, but it looks like the tire was driven on flat. Hence why the tire separated the way it did.
Any shavings of rubber laying inside the rim?
Old Jul 15, 2011 | 12:36 PM
cookba's Avatar
thats crazy man. im on my 2nd set of NT05's and put 15k-20k of hard miles on them with no issues.
go back to DT and have them looked at, that should warrant a new set.
Old Jul 15, 2011 | 12:43 PM
SAchris's Avatar
They are no where near bald. The picture quality kind of makes it look that way though. I'm going to get out the good camera and get some close ups and high-resolutions for you guys.
It wasn't flat, that is the first thing my dad said when he saw it too. It has to just be a defect since only the outside separated right?
I will check the date on it.
Chris
Old Jul 15, 2011 | 01:02 PM
VinR1's Avatar
with all due respect, I've driven on a flat tire and it separated the exact same way...
Old Jul 15, 2011 | 01:33 PM
JohnnyBz28's Avatar
I have the NT05R's and haven't had any issues ................. and I don't drive "normal" by any means lol. I had the 275 drag radials and took them to the track did quite a few burnouts on them too.
Old Jul 15, 2011 | 01:46 PM
SAchris's Avatar
I've never had it happen to me because I'm **** about maintenance, but I have seen it happen. I fully realize that is what this looks like, but unless my tire went flat during my 15 mile commute and I some how didn't notice it, that is not what happened here. That is a possibility though, i'm not going to say it isn't.
The tire pressure in the other three tires were all 35psi.
Pictures incoming soon.
Chris
Old Jul 15, 2011 | 01:51 PM
SAchris's Avatar
Here you go.
What's up with these cracks?
Chris
Old Jul 15, 2011 | 02:50 PM
Craig Gibbs's Avatar
Take those back to where ever you bought them.. I have those on my car right now with no issues. Going Mickey T from now on though..
Old Jul 15, 2011 | 02:58 PM
BoricuaHec01's Avatar
Formally Simplɘ Jack
Ouch.
Old Jul 15, 2011 | 03:09 PM
the crusty pirate's Avatar
definitely looks like it went flat without you knowing and you drove on it..
Old Jul 15, 2011 | 03:23 PM
JohnnyBz28's Avatar
It actually looks like you might have hit something and took a little piece of the sidewall off...
Old Jul 15, 2011 | 03:28 PM
ilovechevy1's Avatar
i drive around on some 315 MT drag radials..they are awesome..just giving you a hint to the next set you should buy lol
Old Jul 15, 2011 | 04:25 PM
Stippy17's Avatar
It was drove on flat from the pics you uploaded. I understand the other 3 have perfect air pressure. My guess would be a nail or foreign object protruded the tire during your commute to work, or like someone else has said you hit something and punctured the sidewall.
I'm using my phone so I can't see the pics 100% to see if you damaged the sidewall hitting something or if its all from driving on it.
I hope you bought some sort of road hazard, that is the only way your going to get a new tire imho.
Most Nitto's are USA made and I do believe all tires are tested before they leave the factory. They even have a garuntee about the balancing of their tires that if it takes 'X' amount of weight to balance and its not because of the wheel they will replace that tire or the tires. I don't see the tire having been a defect.
Old Jul 15, 2011 | 04:31 PM
Stippy17's Avatar
And because a tire was driven on flat doesn't mean both sidewalls would separate..all depends on the tire and how long the tire was driven on flat/how fast it was driven on flat.
I've seen some tires that don't separate at all, but they have a few cups of rubber shavings inside. Usually there will be an indentation around the tire that I like to call a 'death ring' because the tire is junk at that point. But I have also seen some tires that give no indication it was driven on flat, but you dismount it and there is shavings. A lot can happen in the world of tires.
I've had to dismount tires that were driven on flat where all that is LEFT is the 2 beads and they are still seated. The whole centersection and sidewalls are goneee and sitting on the side of the road somewhere..
Old Jul 15, 2011 | 04:38 PM
SparkyJJO's Avatar
I suspect you drove over a nail or something that made it go flat really fast, explaining why you wouldn't have felt flat earlier, then of course it tore up because it was flat.
Old Jul 15, 2011 | 05:01 PM
leadfoot4's Avatar
Originally Posted by Stippy17
.....I've had to dismount tires that were driven on flat where all that is LEFT is the 2 beads and they are still seated. The whole centersection and sidewalls are goneee and sitting on the side of the road somewhere..
I know what you mean. My wife, God bless her little heart, did that once, after running over a bungee cord on the road, and not realizing the tire was flat for about 3 miles......
Old Jul 15, 2011 | 05:05 PM
JohnnyBz28's Avatar
My nitto tires say made in japan lol......
