These lug washers are driving me
I have some new Weld RT-S wheels for the track that have the washers on the lug shank and the washers keep falling off inside the lug holes and then you can't get the lug nuts the rest of the way on.
My buddy has this same problem with his drag stars.
Anybody solved this headache?
They can be tricky, best way is to use a delicate touch and thread them on by hand until they are on far enough that the washer can't fall off the shank. Again, threading them on by hand worked fine for me.
Lol.... I have the same problem its even worse when you have longer wheel studs, I've looked for a lug with the washer combo where they don't separate and had no luck.
What you have to do is take your time and be patient. Also when it falls of the lug nut rotate the wheel while continuing to tighten the lug nut as long as it is not wedged in between the lug and rim you can usually get the washer to fall back onto the lug nut without taking it back off and starting over.
