Help me with my stance looks cool on vdubs but not this ahhhhh
Old 09-01-2011 | 10:38 AM
  #41
Xsta Z 28's Avatar
if they are 9" to 9.5" wide, yes a 275/40R17 will be perfect.
BTW I run 38 mm offset wheels without issue . .
Old 09-01-2011 | 11:11 AM
  #42
donati98ta's Avatar
thanks ,
yep there 9.5
Old 09-01-2011 | 11:17 AM
  #43
99FormulaM6's Avatar
So how did you go from testing them without the spacer and saying it rubs, to now finding out it doesn't rub...?
Old 09-01-2011 | 12:12 PM
  #44
kinglt-1's Avatar
Originally Posted by donati98ta
im dumb, it works without the spacer. i have about 1/8th of an inch between the upper brace and the rim.
Grab your hard hat & crayons and run like hell!
Old 09-01-2011 | 02:49 PM
  #45
desertLS1's Avatar
LoL just wow...
Old 09-03-2011 | 03:46 PM
  #46
ChaSSe's Avatar
offset is a + 45 but its got this massive papper weight spacer 2 inches thats + another 50 mm. so its + 95 wtf
i can keep the wheels then do a + 10 mm spacer be at +55 and it should do fine ?
would i need longer studs for this to happen ?
based on this thread i need to fall in between 50- 56
https://ls1tech.com/forums/wheels-ti...must-read.html
+45-50=5mm
Spacers dont add they subtract.
Old 09-04-2011 | 01:22 PM
  #47
IWGF's Avatar
Fail....
Old 09-04-2011 | 03:51 PM
  #48
desertLS1's Avatar
Originally Posted by IWGF
Fail....
LOL
Old 09-04-2011 | 09:57 PM
  #49
Cobra2WS6's Avatar
Some people kids right!!
Old 09-05-2011 | 08:08 PM
  #50
69TA's Avatar
how are the tires even staying on the rims on the blue VW?
Old 09-05-2011 | 08:27 PM
  #51
tillery's Avatar
Its air ride equipped. According to the sticker on the trunk. But this stretched look was a thing in the 80s on mini trucks. Ever see a 205/50/15 stretched on a 10 inch wide rim? Safe? Not really. Only saw a few come off. I would never do this. Even if it looked cool back then to show the rim lip.
Old 09-05-2011 | 08:32 PM
  #52
allout06's Avatar
ground. got a offset pro looking at it tomorrow. ill take lots of pics.
offset pro? did he go to college for this?
Old 09-06-2011 | 11:35 PM
  #53
ANTICOP RAM AIR's Avatar
I got so agitated reading this bullshit, I was yelling at my computer... Is this what nerd rage feels like?..
Old 09-06-2011 | 11:37 PM
  #54
Originally Posted by desertLS1
LOL
It's strange seeing your sig without the SS.... I see you traded up though.
Old 09-07-2011 | 12:39 PM
  #55
carlos64030's Avatar
I'm dying to read the explanation on how these wheels suddenly seem to fit now.
Old 09-07-2011 | 02:34 PM
  #56
redtan's Avatar
Cocaine is a helluva drug...
Old 09-07-2011 | 05:47 PM
  #57
9WhiteCamaro9's Avatar
Maybe they were using the spacers to bring the wheels/tires out to be flush with the fender. I have no idea what size spacer would be needed to bring the fronts out to be flush with the fenders to know. Wasn't there threads about this not to long ago?
Old 09-07-2011 | 10:03 PM
  #58
ChrisRZ28's Avatar
I've got a 3/4" spacer (ARP studs) on a 56mm ZR1 on my car. The tire is still a 1/4" inside the fender, although it looks a little further in then that. Optical illusion I guess.
Old 09-17-2011 | 10:42 AM
  #59
ScrapinBye's Avatar
I have a similar setup, with the C5 DD machine face wheels 18x9.5/18x10.5. I run 285/35/18 tires in the front and they fit great. I did however end up installing some 1" wheel adapters in the front cuz the wheels looked way too tucked in. They almost looked "sunken", plus the fact i have Eibach sportlines and the negative camber is making the top of the wheels lean towards the center is magnifying that "tucked in" look. Those wheel adapters look great, and brought the tires ALMOST flush w/ the fenders.
Old 09-18-2011 | 02:37 PM
  #60
Spd-Kilz's Avatar
Originally Posted by Scott97LT1
BFH mod + remove spacers = voila!
This is TERRIBLE advice. You can't BFH the front.
