17x11 the holy grail?
There should be a lot of 17x11 wheel choices that are under $1000/apiece (assuming you weren't just exaggerating for effect
). The 17x11 ZR1-style wheels come to mind - should be able to find those for a very reasonable price. Might contact Todd at Discount Tire and see what he can do for you.Also, I know that there are a handful of guys running 315's on all 4 corners. Not sure what mods if any needed to be done to handle that size. I believe mitchntx, for one, was using 315's in front and rear - maybe contact him regarding what was required to make that work.
17x11s with 50mm offset will fit on the front with just a 7/32-1/4" spacer. From all the research I've done, I've heard of no other mods required. I'll have 17x11's on all four corners by the end of April at the latest. Currently waiting to see if the search for a 17x11 WS6 wheel manufacturer pans out and what the cost ends up being.
Take a look at www.billetwheel.com Anything in the forged line, and signature series can be made in a 11". There wil be more options, and there are options already well under 1000
As far as rubbing issues, there aren't any.
