C5 Z06 wheels on WS6
Old Nov 29, 2011 | 02:13 AM
weslp00's Avatar
Default C5 Z06 wheels on WS6
Hi guys Newbie here,
Want to put my C5 Z06 wheels on to my 2000 WS6.. I am sure they fit and all but I got a question about the fronts/sizes etc....
Why is it that the WS6 front rim is 17x9 with a 275 size tyre and the Z06 is 17x9.5 with a 265 size tyre..same profile..what gives I dont get it, thought the bigger rim would have the bigger tyre???
Look forward to some answers..
Cheers,
Stuart..
Old Nov 29, 2011 | 02:32 AM
myk's Avatar
myk
I thought the Z06's front tire was supposed to be 275? Vette owners feel free to correct me...
Old Nov 29, 2011 | 02:36 AM
Maroboy's Avatar
I could be wrong but corvettes have 265 on the front.
I had 265s on my ss. They look funny. To small IMO. 275s look perfect on fbody.
265s look good on corvettes.
275/40 Is the right size for fbody.
I also had 285 on the same rim. Fits good but is to wide for the front
Old Nov 29, 2011 | 02:39 AM
myk's Avatar
myk
I wish my Speedlines were 245 up front. Isn't the base 'Vette that size up front?
Old Nov 29, 2011 | 02:52 AM
Maroboy's Avatar
Yes the front is 245/45 and the back is 275/40 17s front 18s in the back. On the base C5. I'm not sure how wide is the rim tho.
When I bought my c5 zo6 rims came with 265s on the front
Old Nov 29, 2011 | 03:32 AM
weslp00's Avatar
Default WS6 rims
Still seems wierd to me .. 275 on a 17x9 T/A rim and a smaller 265 on a 17x9.5 bigger corvette rim.. Why does the factory do this?
Old Nov 29, 2011 | 03:56 AM
Maroboy's Avatar
Good point. But that's probably bc the Fbody is a bigger car than corvette.
Camaros also come with 275s on 9 inch rim I believe. Not sure.
Old Nov 29, 2011 | 04:08 AM
weslp00's Avatar
Smile
Ye your right .. the Corvette is a lighter car..now i've got an idea..! Might just take the 275's off the WS6 rims and put em on the Z06 rims.. job done!
Old Nov 29, 2011 | 04:25 AM
Maroboy's Avatar
That's right! You'll be happy with it.
What size tires you gonna put on the back?
305/315s looks & fits perfect on the back rims
Old Nov 29, 2011 | 04:27 AM
weslp00's Avatar
Still got 295/35's on the back 10.5 inch rim.. will a 305/315 fit .. must be tight on the T/A rear arch?
Old Nov 29, 2011 | 04:32 AM
Maroboy's Avatar
I could be wrong but I think on T/As fit fine with no modifications needed.
On my ss I got 295/35 they rub alot on turns
The way to fix that is hitting or cutting the inner fender in case you need to modified to make them fit.
Is your car lowered?
Old Nov 29, 2011 | 04:42 AM
weslp00's Avatar
Stock at the mo and dont want to lip the rear arches.... also im in the Uk .. and dont see many 315/35 x 18 on fleaBay... got any suggestions on tyre make so i can narrow search for 305 and 315.. this is getting better.. get back to you later gotta go out..
Cheers,
Stuart..
Also.. are the issues with the Z06 wheels being differnt diameters and ABS etc ..will it bring up any codes??
Old Nov 29, 2011 | 09:19 AM
ANTICOP RAM AIR's Avatar
I have a set of C5 Zo6s (17x9-18x9.5) on my 99 TA... No codes and I also run a 255 tire on the front. I found it makes the car less inclined to follow the grain of the road. I dont AutoX it or anything so the amount of grip isnt so important that I need the wider tire. It also handles better in the rain with the narrower tire. I still have 275s in the rear and my stance looks just fine...
