What other cars have the same lug pattern
Sorry to bring this thread back from the dead.
I was wondering if there is a difference between the lug pattern on LT1 T/A's and LS1 T/A's... I know, stupid question right?!?!
I am looking at buying a set of C6 rims. They claim in the add to be 5x4.75 or 5x120.65 -18 x 8.5 fronts, and 19 x 10 backs. The guys selling them said that they will fit an LS1 Trans, but not my 94 LT1??
I thought this seemed weird, and just wanted to check with the experts.
Thanks for the help.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
@94LT1TA6speed I may have an answer to that lt1 cars hub is slightly larger than the ls1 cars so that means ls1s and newer are backward compatible with lt1 and older rims however all it takes is a dremel tool to the center hub opening on the wheel for you to put an ls1 wheel on your car tho most Aftermarket rims have addressed that minor deference anyyou could use a longer wheel stud if you don't have the avability to do that and a 1/8 inch spacer there used to be a thread about this but that was along time ago or you can swap to ls1 spindles and get an ever so slight brake upgrade also change your rear axles for a newer one and then you don't have to worry about it thats what I did when I had an lt1 car
