Fbodies with 5x120 wheels come in
The usual basic bolt-ons, cam and converter coming next. Probably won't go too far with it as I'm looking to add a 'vette to the stable in the next couple years.
I'm not sure what he means, all the lugs should fit fine. Maybe you might need hubcentric rings depending on the wheel?
Cash is one thing, but as far as the wheels go they WILL fit. As far as the guy at the shop, it's his job to try and talk you out of it. They weren't made for our cars so a business wouldn't put them on. Plenty of us run them without issue, it's just something to be aware of and like I said, for peace of mind check the lugs regularly.
I ran 5x120 for a very long time with 0 issues. I had a set of 19" axis super hiros, and also a set of 19" ruff racing 278's..
I say again..they bolted on fine, did not rub and I was sitting really low..check my album
But know that I tried to swap those 278's over to my z06, and they bolted on ...but they stuck out past both front and rear fenders about an inch..
The tires weren't wide either..295 rear..265 front..
