Check my wheel math? (please and thank you)
I picked up a set of CCW Classics recently that came off of a C5 Corvette. Specs are below.
Fronts -
9" width, 10" overall
Front lip - 1.5"
Rear lip - 8.5"
Backspacing - 7.25"
Offset - 57mm
Rears -
10" width, 11" overall
Front lip - 2.5"
Rear lip - 8.5"
Backspacing - 7.75"
Offset - 57mm
What I'm wanting to do is run the current 'Rears' on the front of an f-body, and replace the 'Front' front lips with 3.5" instead and run the current 'Fronts' on the rear of an f-body.
My math says that adding the additional 2" to the lip (making it a 3" functional area) makes the new offset 44mm
228.6mm (9") + 51.8mm (2") = 280.4mm - 184.15mm (7.25" backspacing) = 96.25 (wheel width in front of backspacing) - 51.8mm (front lip) = 44mm offset
Is this correct?
Fronts -
Front lip - 1.5"
Rear lip - 8.5"
Backspacing - 7.25"
Offset - 57mm
Rears -
Front lip - 2.5"
Rear lip - 8.5"
Backspacing - 7.75"
Offset - 57mm
Is this correct?
Almost
Backspacing stays the same since the additional width is on the face side of the wheel
Offset is changed +/- by exactly half of the additional width...assuming only one side of the wheel is being modified (adding an inch to the front and back of a wheel and the offset stays the same)
In your case, adding 2" (51mm) affects the offset by half (25.4mm). So 57mm - 25mm = 32mm offset.
An example would be if you had an 8" wide wheel with 0 offset - if you had the inside of the wheel widened 2", you would now have 4" to the outside and 6" to the inside. The wheel centerline is 5". So 6-5=1 or an offset of 25mm
A 11" wide wheel with 32mm would be a super tight fit and would probably rub your quarters even if you ran a narrow tire and rolled the fenders. I have 36mm offset ZR1s and they rub the quarters on hard turns...lemme know if you want pics
Ah that makes sense. Thanks.
That does sound like it would be a pretty tight fit. Is your car a Trans Am? If you could send/link pics that'd be cool. Plans for the next car involve extensive handling modifications and I don't wanna be slamming the tire into the quarters all the time, so I may go with a 3" lip instead of the 3.5"...or not do it at all...
That looks great. I dunno, 1/8" further out than that wouldn't be terrible I don't think. I'm planning on either a rod ended adj panhard or a watts link on the new car and Strano springs. I may go with the 3.5" lips...I think it'd look pretty killer...
What are your thoughts? Be 'safe' with the 3" or go with the 3.5's and hope for the best?
