17 x 9.5 torque thrusters
Old Dec 23, 2011 | 09:31 PM
slimmer's Avatar
Default 17 x 9.5 torque thrusters
I have on a 98 ta vert. Any one know how wide of a tire i can put on these. Right now they have 245 45 17 on them and they look small.
Old Dec 23, 2011 | 09:41 PM
jenks40's Avatar
9 1/2 is perfect for a 275 width tire. You could probably go a little larger, but 275 will fit best and be your most available and cheapest option.
Old Dec 23, 2011 | 09:59 PM
slimmer's Avatar
stick with the 45 then. Won`t they be too tall.
Old Dec 23, 2011 | 10:32 PM
1badchicken's Avatar
I would go 285 on the back and 275 on the front
Old Dec 23, 2011 | 11:07 PM
Donohue96M6Z28's Avatar
Go with the 40 if you're going to 275 or 285.
Old Dec 27, 2011 | 08:38 AM
pjb's Avatar
pjb
I have them with 275/40/17.
fit perfect.
Old Dec 27, 2011 | 09:52 AM
82cetuner's Avatar
275/40/17 is exactly what the ws-6 package runs, its a perfect tire and same height. i still run 275/40/17s when I switched to TT2s but the rim size stayed the same 9.5 width was stock on ws-6
on the rear you could go to 285s on the 9.5s but why not get you some 11 inch TT2s and throw some 315s out back, will look bad ***.
Old Dec 27, 2011 | 09:53 AM
82cetuner's Avatar
and yes 45s will be to tall for 275s
Old Dec 27, 2011 | 04:13 PM
9WhiteCamaro9's Avatar
WS-6 and SS's came with 9" wheels. A lot of aftermarket companies make 9.5" instead but yes a 275/40/17 will work best with 9.5" wheel but I would go with 11's out back with 315/35/17 tires. Would look a lot better than the 9.5's all the way around.
Old Dec 27, 2011 | 04:45 PM
99zee's Avatar
Originally Posted by pjb
i have them with 275/40/17.
Fit perfect.
x2.....
Old Dec 29, 2011 | 05:42 PM
slimmer's Avatar
So fronts are ok at 275/40/17. I just got a good (canadian deal) on a set of 275/40/17 fuzion zri's. Now i need something to match either front or back. I think i can still get a set of the same tires But if i understand right fuzion quit making them.
Old Dec 30, 2011 | 12:00 PM
supersick99z's Avatar
I run 275/40/17 nittos all the way around on mine. Mainly so I can rotate them
