16x10 tire question
16x10 tire question
Looking at a set of CCW classics 16x10 all around but have no idea where to start with tire sizes any help would be much appreciated been searching in wrong areas maybe someone on here can guide me in the right direction please!
you can do the 16x10 on the rear have no idea what kind of tire you could find for the front if you decided you were to run a 16x10 in the front. You will be limited on tire sizes for the rear either way. MT makes a drag radial in a 315/45/16, 295/50/16, a couple of ET streets and Hoosier and M & H make a couple of tires.
The thought of selling my 16's has run through my head on more than one occasion to make the switch back to a 15" wheel for the purpose of weight reduction and a huge amount of tire choices.
I looked into this in the past wanting to do something silly like widen my stock rears to 10" and 275/45 is the widest and only tire size I know of to fit a 16x10" but those would be full competition tires only. The widest street tires I know of for a 16" rim would be 255/50 but those would have to be stretched onto a 10" wide rim.
but they would fit right? i was thinkin the 315 rear and if the 255 would fit go with it itd be a dd so idk if i should just keep looking for wheels or go with it and im not sure how the 16s would look either its a lowered white ss
I've seen cars with 225's stretched on a 16x10's so a 255/50 will be fine. Just be aware its out of the recommended MFG rim width for that tire size and will have a little stretch to it so the rim might stick out a little farther than the tire but nothing crazy.
