285/35/18 rear tires rubbing need help
Hey everybody , does anybody know what this can possibly be , wheneva I wanna accelerate alitte harder than the norm , I get a strange grinding or rubbing noise coming from underneath the chassis towards the rear at first I though it was bad springs but I recently change the. Springs and still get the grinding noise but not as bad what can this possibly be , all advice is appreciated I know it's the tires rubbing but against what idk pls help
the brand of the tire may help.. they may be labeled the same but believe me, they are different sizes... take off the wheel and see where it is rubbing... smack the **** out of it what a 1lb sledge hammer and a 2x4.. then spray with undercoating... 18" tires put the crown of the tire higher into the wheel well where there is less room for a wide tire... especially if youre lowered..
You tell us man. We can't take your wheel off and inspect it for you. Take it off and look at the tire to see what part of it is rubbing. Itll be noticeable. Then look at your inner fender, lca's, quarter panel, etc and see what its rubbing on.
just look at the tires you don't even need to take them off the car to figure it out.
if its slicing on the outside of the tires by the sidewalls then you need to roll your fenders and I have the roller tool for rent (see sig below).
if no signs of slicing on the outside then it's the inner wells that need a good old fashion beating.
the offset will make certain tires rub, also the diameter will make a difference...these tires were on knockoff C5 spokes. The tires were 295 35 18 KDW gforce TAs...
here are some pics when I did mine..
what a 275 17 looks like next to a 295 18..
tire rubbed here..
I dont have a pic of the BFH anymore but I actually used a 25Lb solid cast dumbbell... haha you can tell where its rubbing either on the tire/rim or inside like mine was...
tire rubbed here..
