got the weld rts and they don't look like they fit any help?
#42
Not unless I wanted to mini tub this thing or do alot of cutting and beating I guess they make offset lca's that was going to be my next thing try but the 4.5 work and look way better IMO
#45
My rear end in my car is cut 3.75 on each side Street wheels are 17X11 4.50 B.S. and drag set up is 15x10 3.50 B.S. fits nice looks good.Mine is a Trans am . Trans am is a little wider then a Camaro .Camaro you need to cut 4.25 on the rear end if you want to run this size of rims.
#46
4.5 is not gonna work with a 2.5" narrowed rear. mine is narrowed 3" each side and i cant decide if i want to send the 4.5" back for some 5.5" and run a spacer or try them as is. the 4.5" is boarder line on if it sticks out to far on my 3" narrowed/side
#47
Did you see the pictures I posted with the 4.5?? Def alot better than the 5.5 think what u want but I seen it first hand!
#50
I also questioned this at first and called mwc and confirmed that it was 2 1/2 on either side I also did measure, It I forgot what that measurement was.
Dj what is the length of yours and I will put a tape up to mine.... Car is not at my house so I will need to get back to you on my measurement.
#52
I just went back in emails and seen that my rear was org 2.5 and we changed it to 3.....wow fml
I even measured it and talked to mwc and they said it was 2 1/2 they must of been tired lol
#53
hmm ok.. did you have rotors on when you put the wheels on to measure? Sometimes I forget that part lol.. When I put my wheels on 2 nights ago it looked like your pictures but I had no rotor. My rear is covered by a bunch of **** right now in the corner so tomorrow I will clear it out and get measurements.
