Rubbing w/275/40/17 on PASS front only!?!?
Well went and test fitted my buddies TTII's on my front to see where I rub because I had a feeling I would somewhere. And sure enough. I rub on the passenger side. Same exact size I plan on running 275/40/17 17x9.5
Doesnt rub at all on the driver side, just clears it perfectly.. Here are the spots that it knicks on the passenger front.
Should I beat the wheel well in that spot? What about the part with the GFX? Any way around it..or Do I have to take off the front gfx??
Car was also involved in a minor accident where it rear ended a vehicle..or so carfax report said
Last year I was in reverse leaving my storage unit and there is a dip. I didnt realize how close I was to it and ended up bottoming out the front. Pushed my front passenger GFX off a bit and the front of my pass side. I dont know if that had to do with the rubbing or not?
