Where to get '98-'02 SS wheels?
Old 04-06-2012, 09:38 AM
WhiteKnight '01's Avatar
Default Where to get '98-'02 SS wheels?
I'd like to upgrade the wheels on my Camaro, the snowflake wheels arne't cutting it anymore. Economy cars come stock with 17 inch wheels now, so my 16 inchers look pretty small.
Anyone have any idea where I can get a new set of SS wheels? I'll even take a used set in good condition for a good price.
Also, will I have to recalibrate the PCMfor 17 inch wheels? Or will the MPH not be off enough?
Old 04-06-2012, 09:46 AM
Super Moderator
Reckless's Avatar
http://www.oewheelsllc.com/Wheels_3/Wheels-for-Camaro_4
Old 04-06-2012, 09:48 AM
Thanks a million!
Old 04-06-2012, 02:55 PM
Nathan C's Avatar
If you get 275/45/17 it will not mess up the odomoter. No need to recalibrate anything.
Old 04-06-2012, 11:32 PM
Tommyv8's Avatar
That's right, the tire height will be the same.
Old 04-07-2012, 12:41 AM
Tire height is the same but I need a different set of tires, am I right?
Old 04-07-2012, 09:23 AM
Tommyv8's Avatar
Yes. For 17x9 wheels you will need the size that Nathan specified, 275/45/17. A little more expensive than 245/50/16 but still reasonable.
Old 04-07-2012, 12:43 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,761 Likes on 1,258 Posts
You definitely do NOT need 275/45/17 sized tires. You want to get 275/40/17, which was the stock tire size for an SS.
If you go with 275/40/17 you will not need to change anything with shift points nor speedometer readings. The height difference is only .01" (25.65 vs 25.66) between your stock 245/50/16 tires and the 275/40/17 SS sized tires.
Old 04-07-2012, 01:52 PM
Cool, thanks for the input. Just wondering, why are the tires for the 17 inch wheels so much more expensive?
Old 04-07-2012, 01:57 PM
Tommyv8's Avatar
Whoops, sorry for the bad info.
Old 04-07-2012, 10:34 PM
TransAmWS.6's Avatar
Because, the SS 17's need 275's compared to the 245's that you have on your car now, it's just a beefier setup.
Old 04-08-2012, 07:22 AM
Tommyv8's Avatar
Tires for larger diameter wheels are more expensive, even with identical width. This is odd to me since with a shorter sidewall the tire uses less rubber. Is it because the sidewalls have to be stronger?
Old 04-09-2012, 06:09 AM
nascarnate326's Avatar
I think you are correct.
I am sure sales numbers play into the pricing as well.
Old 04-09-2012, 09:23 AM
JACornell's Avatar
I think it is because the tire manufactures can charge more and justify that the mold used for them cost more regardless of about of rubber used to make them.
In other words they charge more because they can.
Quick Reply: Where to get '98-'02 SS wheels?
