C5 Corvette Wheels Fit 3rd. Generation?
Tried searching and couldn't really find any info....Anyone know if spacers (adapters) are needed to run OEM C5 wheels on the 82-92 Camaro?
Fronts should fit fine
Rears are going to be the the headache. Most guys run a small up to 1.25" spacer/adapter depending whether theyre GM wheels or replicas with a smaller offset. Add in the fact that your rear is around 1.5" narrower per side so you may end up needing a 2"+ spacer
