Plug in MT Sportsman
Old Jun 8, 2012 | 12:04 PM
roninsonic's Avatar
Default Plug in MT Sportsman
So, I somehow got a hole dead in the middle of one of my two month old MT Sportsmans. It was a small hole, I had to work to get the reamer through the tires. The hole was pretty much dead center of the tread, in between two thread blocks. I reamed it, covered one of those really soft super sticky tire plugs in rubber cement, and plugged it. After plugging and trimming the plug even, I lit it for about 10 seconds to try to heat the plug a little and get it to bond with the tire and to cure some of the cement.
It seams to be holding air just fine, no leaks that I can tell, but it's only been a day.
What are y'all's opinions on runnining this tire? I don't go to the track much, but I DO dick around on the highway a bit. The tire has pretty much ZERO tread wear.
Old Jun 9, 2012 | 01:35 AM
roninsonic's Avatar
c'mon, no answers?
Old Jun 9, 2012 | 05:25 AM
Zombiesoldier's Avatar
i know someone who did it on et streets. he never had a problem, but his didnt hit the strip either.. soo....
Old Jun 9, 2012 | 05:31 AM
roninsonic's Avatar
I wouldn't be too worried if it was a rear. My main concern was that it's a 7.5in front runner.
Old Jun 9, 2012 | 05:38 AM
get it unmounted and get a patch put in if it worries you that much
