Z06 Spyder rims and ctsv breaks: PICS ADDED
love them! any spacers needed for the front to make room for the brakes? got a pic of the rear, i wonder how a 40mm offset looks back there.
Wonder if I could get a deal from 6litereater if I bought these for my Camaro and G8!!!
Yep everything bolted right up just perfect. No spacers just the normal washers for the calipers offset. The front tires rub a little when I turn all the way. No big. I will wash her and post up some more pics sometime soon.
The tires hook up a lot better than the previous faulkens?spelling?. I'm sure the stock rear isn't very happy about it. Cornering is tons better and now the age of the suspension really shows. Maybe some konis and poly bushings will help a little...or........maybe i just need a frc vette to put this motor into.
sweet! i saw you said they were rubbing and was like WTF then I re-read the OP and see you are running 295's on all 4 corners, luckily i only plan to run 275's. Maybe a 3mm spacer will help clearance and give you room to lower it. my Koni's and Strano swaybars and springs was my favorite and most noticable mod.
