Help with tire choice
Old Jul 1, 2012 | 02:06 AM
450xguy's Avatar
Default Help with tire choice
So after waiting over a month the tire store called and said my rims will be in this week. I ordered TT going 9 in the front and 10 in the back. i told the guy i wanted some lip in the rear so i hope they come the way i want them. Now he recommended running 255 in the front and 285 in the rear. He also suggested the Nitto 555's. Im here looking for advice because if i recall reading here on the forums i can go wider in the rear so let me hear some recommended sizes width profile and brand please. the car is going to start seeing minimal track time so i want a good street tire and something that hooks up fairly decent at the track. they are going on a 02 Z
Old Jul 3, 2012 | 06:59 PM
Cape T/A's Avatar
A nitto 555r may be your best bet for the rear and regular 555 for the front. The sizes he recommended sound right, a 295 would maybe work in the back
Old Jul 3, 2012 | 07:05 PM
JUSTINSWS6's Avatar
I would do 295 like he stated and those tires would be great!
Old Jul 3, 2012 | 08:02 PM
450xguy's Avatar
Sounds good im feeling the 295 o yea just picked em up today rear are 10.5 instead of ten
Old Jul 3, 2012 | 08:10 PM
hiram007's Avatar
^This.
If you have 10.5's you can probably go 305 or 315, everyone else does
Cape T/A's Avatar
Then definatly do at least a 295!
Old Jul 3, 2012 | 08:12 PM
450xguy's Avatar
Does a 305 or 315 fit without issues...sittin stock height no mods to suspension
Old Jul 3, 2012 | 08:16 PM
hiram007's Avatar
305's for sure, 315's most likely but it would be a good idea to get an adjustable panhard bar just to be sure. Keep in mind that if you lower in the future, it may become a problem even with the phb.
Old Jul 3, 2012 | 08:17 PM
JUSTINSWS6's Avatar
Ya i run 315 toyo r888 proxe drag radials on a 10.5. I did the bfh mod which is get a rubber mallet and just hit the inner fender in just a little mine dont rub at all and i pick up the front on launches pretty hard. I know people run 315 nitto tires too with no prob i would for sure run a 315 either one i mention are great wide and great traction tires.
Old Jul 3, 2012 | 08:21 PM
450xguy's Avatar
Going this wide is it highly recommended to get a.panhard bar then and adjustable or non
Old Jul 3, 2012 | 08:24 PM
Cape T/A's Avatar
if you get one it would need to be adjustable so that you can get the axle perfectly centered in the car so neither side rubs.
Old Jul 3, 2012 | 08:27 PM
450xguy's Avatar
Sounds good think ill go with the 305 really dont want to do bfh mod lol looking forward to mounting these. Sounds like ill be able to hook up and add some sex appeal rockin the stock 16s now and its annoying just going and hammerin it then they start spinning
Old Jul 3, 2012 | 08:28 PM
baalic's Avatar
I would run the factory sized 275 in the front, unless its a drag car only, then a smaller wheel/tire wouldn't matter...but that's mho
Old Jul 3, 2012 | 08:31 PM
450xguy's Avatar
No its my daily but want to keep it strip friendly since i plan to go at least once a month
Old Jul 3, 2012 | 08:36 PM
baalic's Avatar
Then I would still keep the 275 in the front. A little more meat on the road isn't going to hurt your daily.
Old Jul 3, 2012 | 08:38 PM
450xguy's Avatar
Sounds good so 275 up front with 305 out back and adjustable panhard and ill be set right
Old Jul 3, 2012 | 08:39 PM
baalic's Avatar
Sounds Sexy already..
Old Jul 3, 2012 | 09:39 PM
450xguy's Avatar
Anyone know a vendor that sells 305 in a 17 wheel
Old Jul 3, 2012 | 09:42 PM
baalic's Avatar
you could get a 315 in a Nitto if you don't mind a little "cheating"
Nitto goes from a 285/40 to a 315/35 in their street tire 555, In an 18" they have a 305 DR..
Old Jul 4, 2012 | 11:22 PM
450xguy's Avatar
looks like im going with a 285 then for the rear...i cant find anything in a 295 or 305 for a 17 that isnt a DR, And im not all about running a DR since this is my daily and dont want to replace tires every 3 months
