18" tire question
275 = section width in MM (1 inch equals 25.4 mm)
35= sidewall height 35% of 275mm
275/35 = Aspect ratio
I think the 275/35 would look a little short.
Look at 285/35R18s in rear & 275/35R18s in front if you like lower sidewalls.
Toyo makes the T1 Sport in both sizes, so Nitti probably does as well.
Cowpunk
And, I've sold tires for 25+ years. 35's will have a shorter sidewall than 40's.
Potholes will still be tougher on the 35's than a 40's.
If you think the shorter 35's would look better, get them. That's what I would do too.
Cowpunk
Here's a few more stock tire sizes I forgot to add.
235/55/16 = 26.18"
215/60/16 = 26.16"
The 285/35/18 will fit... it will rub the plastic fender liner in the front just a little.
(I know because that size it what I as running.)
