Whats needed to fit 19x12 345s?
I installed the 1/4" spacers i made and the adjustable panhad bar...it clears now but these eibach sportline springs are to loooow so ill be installing the bmr springs and rolling fenders....adjustable bmr lca's will be here thursday as well.....slowly but surely.
Installed the bmr springs and kept isolater on top. Also installed the adjustable bmr lca's...everything clears now. Its drivable but still need to roll the fenders..will post pics tomorrow
Looks good im in the process of tuckin c6 z06 19x12 with nto5r 345's . This involves tubbing the rear and coilovers all the way around. Alot more work than i anticipated.
#36
#37
i cut out most of my bumpstop and left most the sheetmetal there. only place im rubbing now is at the front inner fender and im masaging that here and there, i painted it flat black in the fender so i can see where it rubs. also, im not running any spacers on my setup, OP is running 1/4in spacers, so are a lot of people.
I'd like to see pics of your setup though for sure!
#38
If i ever figure out how to post pics i will. When i started my project mine were sticking way out resting against the rail . Maybe the nitto nt05r 345's r wider. Idk but regardless i want my **** tuckin somewhat . And that aint happening stock. I do love the way 345's look from the back
#39
i just completely removed the bump stops then they were rubbing on the lower.control arm and i went ahead and got the tubular adjustable control arms and they gave me plenty of clearance.
i have michelin ps2s and i thought those are the widest among other manufacturers tires.
#40
Anyhoooo... you can use www.tinypic.com to upload and host your photos. Make sure you choose the option to resize your photo to 1024 x 768. Then copy the link that has the [IMG] tags surrounding it and paste it to the text box on this forum you use to make a post.
Here's a tutorial video to help you:
