Z06 Rims and Tires Rubbing
I recently replaced my factory rims with a set of c5 Z06 rims and factory 295 tires. I put i believe a 1/4inch spaced on them and they are rubbing on the inner fender lip on both sides destroying my sidewall. I cant afford to rent a fender rolling tool, so i plan on cutting the inner fender lip, around the spot welds and pushing the spot welded areas up. Unless anyone else has a better idea, i can really use some help and the search feature isnt helping!! Thanks!
craigslist!! lol. When I put on my wheels/adapters I was hitting the fender too. Couldn't find anyone on my local forum with the tool, so in a panic, I checked out craigslist. Found several local people doing it, and went to one that same day and got it done for like $60
heres a question im wanting zo6 rims but im gonna do 275-40-17 all around rims are 17x9.5 tryin to figure out if there gonna rub before i buy. so do you think they will rub?
