Wide 11 or 12 inch wheels on the back? lol
I am running the 17X11 AR Torq Thrust M wheels out back and they don't rub one bit. Even with the car lowered 1" it hasn't been a problem. I tried running an 18 inch C5 Corvette wheel at one time and it rubbed every time i went over a bump. I don't know the exact specs on any of these wheels, sorry.
I think the issue is with 18" on up. With the larger diameter you will have some rubbing issues if your car is lowered and you want to go that deep of a wheel. I even tried fitting a 19" C6 wheel but had to add a wheel adapter to make it fit without rubbing. Happy motoring my friend!
A lot of this depends on which brand of tires you're gonna use, preferred ride height and if you care whether your wheels and tires will stick out from under the fenders or not.
Make sure you search the correct wheel offset, tire size and prepare for the possibility of massaging the fenders in places as necessary.....BFH, fender roll, etc.
