if you have the money consider getting a Watts link set up.
with that you can run a 12" wheel with less work because the rear has a lot less
side to side movement.
I have been running 18x11.5" with 315 BFG Drags and they fit fine with out too much issues.
Thanks for the advise bro, and yes I actually plan on doing a 9" rear end from MWC with a watts link. Im saving up money for the rear end right now and the watts link with torque arms before buying some wheels
I'm on 18x12 ccw sp510 with 335/30/18 toyo 888s. Rolled fenders and bfh.. lowered on Eibauch(sp?) With and adjustable phb no rubbing issues. And they tuck up pretty good
Looks clean! Could you post some pictures from a rear view or a rear side view?
I had to do some minimal hammering, but other than that, they fit great. Now, my car is not lowered at all, but when that time comes, I will most likely need to roll the fenders and install an adjustable panhard bar.
