Top end MPH combo 3745R tires
Hi , I'm running now mickey thompson tires , Tire Diameter:25.78 in. , The MPH at the fourth gear is 140MPH @ 6500 RPM
I need something to make the topend MPH taller at the fourth gear because i'm running much nitrous .
How about to run 27.19 in. 295/45-17 instead of my 315/35-17 ? it will worth ?
I knew if i run 18 wheels it won't change anything .
Can't change the rearend gear because im running Dana S60 3.54
