Tallest/widest rim/tire combo for c5 rear
Currently my drag set up is a set of Mickey Thompson et street radials 275/40/17 on 17" z06 front rims which are 9.5" wide I believe? They're a bit shorter than I'd like them to be over my oe overall diameter. Are there any 16's or possibly any wider 15's I can run with wider drag tires for the rear?i have stock c5 calipers and powerstop drilled/slotted rotors that are stock size as well I believe,thanks
