nitto 555R's
Old 03-01-2013 | 01:34 PM
JDEP162's Avatar
Default nitto 555R's
nitto 555R's on the way for the rear, and 555's for the front, 275/40/17 all around. anybody with this setup on a camaro have any feedback/advice?
do you store the drag radials inside in winter because of the compound?
do you rotate them side to side for even wear?
any expirience/info is helpful...
if it matters they will be mounted on c5dd from oe
Old 03-02-2013 | 06:01 PM
yujelly's Avatar
Im not a fan of the 555r's honestly.. I bought a set for my daily driven mustangs second set of rims for track use or street fun and it honestly took forever to heat them up. I had to do a john force type of burn out to heat them up enough but once there they grabbed good but I ended up going back to mt et streets for the car.
Don't leave them out in the elements they'll harden up quicker.
Quick Reply: nitto 555R's
