What tire should I run
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I am going to be buying a set of 18" wheels. I had planed to run 275/35/18's in the front and 295/35/18's in the back. I wanted to run the Goodyear F1 GS-D3's because I like the tread pattern, but they don't make them in the 295's. I have almost given up and decided to run 275's all around. Here are my choices if I run the 275/295 mix. Can you please tell me what tire you would run and why. Please keep in mind that I want an aggressive tread pattern and won't be driving the car in the rain. You can see all the tire at the Tire Rack------>
Kumho Ecsta MX
Michelin Pilot Sport
Pirelli PZero Rosso Asimmetrico
Yokohama AVS Sport
Thanks,
Jason
Kumho Ecsta MX
Yokohama AVS Sport
Thanks,
Jason
Originally Posted by 2xLS1
Firehawk SZ50 EPs. 275x40x18
I think the size needs to be a 275/35/18. I ran SZ50's on two other cars and they were good when they were new but traction wasn't good after about 6 months and less than 2k on the tires.
The EPs are a supposedly a lot better tire. Looks like 275x40x18 is the only 18 they make. That's all they list here http://www.bridgestone-firestone.com/.
from what ive read, the GS-D3's tend to run a bit wider than other tires of the same size, so you might be able to get away with some 285 GS-D3's. just something that might be worth lookiung into, good luck!
