235 on a 4" wide wheel?
Old Mar 26, 2013 | 01:59 PM
sprayedenali's Avatar
Default 235 on a 4" wide wheel?
has anyone run a 235 wide tire on a 4" wide wheel?
Old Mar 26, 2013 | 04:24 PM
sabersaw30's Avatar
I would say you need a 6 inch wide rim for a 235.Here is a chart. http://www.team3wheels.com/tech_specs_tire_chart.html
Old Mar 26, 2013 | 05:02 PM
leadfoot4's Avatar
235/75,
235/60,
235/50?
Old Mar 26, 2013 | 07:01 PM
235/75-15 roughly 29" tall. for my truck. it just looks real funny IMO with a tire any shorter than that. especially since im going to have a 30" radial out back...
Old Mar 27, 2013 | 05:59 AM
leadfoot4's Avatar
7" wide rim, minimum, 8" is better. If it's an older Chevy truck, I believe that 8" rims were available from the factory, should be easy to find.
Old Mar 27, 2013 | 08:14 AM
I'm getting a set of bogarts, I can either get a 15x4 or spend an extra $400 and get some 16x5,6,7, whatever... But I'd obviously rather save that money and get the 15x4's... My problem is that the only tires I can find that are tall enough are 235 and wider... So just getting a different wheels isn't necessarily an option. And I have a 235 on a 7" wide wheel right now and it's a little bit stretched out actually
Old Mar 27, 2013 | 01:16 PM
leadfoot4's Avatar
The 235 in 235/75/15, stands for the section width of the tire, in millimeters. 235 millimeters is 9.59". Think about it, would you really want a 9.5" wide tire on a 4" rim?
Are you talking about drag race use, or street/strip use?
Old Mar 27, 2013 | 01:26 PM
clonedws6's Avatar
This sounds like a terrible idea.
Old Mar 28, 2013 | 11:28 AM
redtan's Avatar
That would be like putting a 345 tire on a 8.5" wheel...awful idea.
Old Mar 30, 2013 | 09:19 AM
any more input?
Old Mar 30, 2013 | 07:03 PM
toslow5o's Avatar
any more input?
Really?
I think that is enough input. Try it and see how fast your bogarts turn to scrap metal and good luck finding a shop to mount that for you.
