My 17x11 10 spoke project
OP, what size spacer/adapter are you going to use? I want to widen my 10 spokes as well, however cannot decided on whether or not to go 10.5 or 11 and which size spacers I will need to get it rear flush with the fender. Any advise? Sorry, i'm a noobie when in comes to wheels/tires.
Just used a bfh. Some have luck some don't.
My 17x11s zr1s didn't need anything to make them fit, but, I was running a 315 555r which are much more narrow than a 315 nt05r.
I could of probably used a 1/4" spacer with longer lugs, I still may but for the amount ill be driving on these, ill probably just leave it.
Going to pull off the passenger valve cover seems like one of the rockers is making more noise than it should. Hopefully Chang the oil too. The fusion needs brakes first.
Mounted up, passenger side wheel hits on really bad pot holes so it still needs some finessing.
![](http://i571.photobucket.com/albums/ss158/mcalus/image_zpseada1a44.jpg)
#34
If anyone needs any wheels powder coated message me. I can do a Black Chrome for $125 per wheel. Like this:
[IMG]http://www.columbiacoatings.com/store/i/is.aspx?path=/images/Metallics
/Blck%20Chr%20Wheel.jpg&lr=t&bw=550&w=550&bh=550&h= 550[/IMG]
Check me out on Facebook: https://www.facebook.com/srpcoatings
