Calling all FM5 and Brembo guys!!!!
Wanting to look into a new set of wheels, but I'm really wanting to do the CTS-V brembo upgrade. I read the difference in the 17 and 18" FM5's is made up in the lip, that the centers are the same.. Is that true, and if so does that mean the 18's and 17's would have the same clearance over the caliper? Also, has anyone fit either of these wheels over the CTS-V calipers with or without grinding the caliper? I haven't seen it yet, but hoping maybe someone has. Don't wanna spend $3k+ to find out there's no chance of it.
Profils are lighter and stronger too. 17s won fit the V brakes without grinding. Spend a few more for the Profil 18s and make sure you specify you're putting a BBK on so they can make provisions in the center for adequate clearance.
![](http://i179.photobucket.com/albums/w291/lpe403/Car%20Build/frtwhlbrk2.jpg)
I made them work with 17" ccw classics... Of course had to grind the calipers down and used a hub centric spacer from eibach. They look good thoug. I also treid them with some 18" I forged wheels no grinding needed and still looks greak. Hope that helps.
