18x10.5 for 08 Z06
18x10.5 for 08 Z06
Hey guys. New to the forum. I have an 08 Z06 that's stock short of a corsa cat back. After realizing first and second are worthless without tires. I was wondering what wheel I can run on the back to be able to run a 345/30/18? Don't really wanna go with much of a different design than stock. C5 Z wheels would work if they will fit. Any help is greatly appreciated. As I have found nothing on the net. Thx Joe
335/30/18 is the closest size I could find that offers any street tires and you need at least a 11.5" wide wheel. If you want drag radial tires then you can get a bfg 345/30/18 and it needs at least a 12" wide wheel.
FYI, you can run a 345/30/19 on the factory 19 x 12 wheels without a problem.
Thx for the info. Was wanting to run a mt drag radial but like u said I guess I need at least an 11.5 to run their 345/30/18. Didn't see that they made one to go on the stock wheels till after i had posted this. Just trying to get as much contact patch as I can on the ground. Thinking cheapest route is to just get another set of stock rear wheels
