315 guys inside>
Old May 3, 2004 | 10:02 AM
ratio411's Avatar
Arrow 315 guys inside>
Can you post a couple things about your use of 315 on the back of your car?
1: Rim dia x width
2: Rim offset
3: Spacers, yes or no (thickness)
4: Problems
5: Solution to problems
6: Linx to pics if you can
Thanks much!
Maybe this info could be compiled into a sticky or archive if we get enough response... Mods?
Dave
Old May 3, 2004 | 10:26 AM
PSU_Engineer's Avatar
I'll start even though I haven't installed mine yet.
1. Rim dia x width
17X11 American Racing Torq Thrust II wheels
Dunlop S8000 tires 315/35/17
2: Rim offset
46mm ?
No
4: Problems
I will edit this post if any problems are encountered. So far all of my research done on this board, LS2.com and CamaroZ28.com have shown no major problems mounting the 17X11 TT II's on a Camaro.
Last edited by PSU_Engineer; May 3, 2004 at 11:05 AM. Reason: speeling and the fact that I'm and idiot
Old May 3, 2004 | 10:30 AM
Brandon98TA's Avatar
1: 17x11 Torq Thrust IIs
2: don't remember, whatever american racing suggest
3: no
4: only if the car is lowered. If so, you will need an adjustable panhard bar, grind down the sides of the bump stops, and cut/roll part of the fender lips.
5: read above.
6: no pics, sorry
Old May 3, 2004 | 01:47 PM
Xsta Z 28's Avatar
No my car, but what wee did:
1. - 11" x 17" ZR-1 Replicas
2. - 50 mm offset
3. - No
4. - Tire rubs inner wheel well, passenger tire rubs outer wheel well lip.
5. - BFH and undercoat the inner wheel well. Adjustable panhard. Sell car . . .
6. - Server down . .
Old May 3, 2004 | 09:28 PM
01 Red WS6's Avatar
1. 17x11 American Racing TT2s
2. ??
3. no
4. rubbing on inner fender well and bump stop hits on wheel when jacked up by frame
5. BFH mod and powder coat. Jack car up by axle
6. Ive got pics of my car with the wheels, if you want pics of the spots to do the BFH mod let me know Ill get some
Old May 3, 2004 | 10:03 PM
Zangel's Avatar
Fiery Features Director
1: Rim dia x width:
17 X 10 Boyd Smoothie II's
2: Rim offset:
38mm I believe
3: Spacers, yes or no (thickness):
no
4: Problems:
Rubs on both sides. I do have an adj. panhard rod and we did roll the fenders a bit. My car is pretty low and the roads in Houston aren't exactly smooth.
5: Solution to problems:
Haven't found one
From the back:
Shows how close the tire is:
This isn't the best picture, but if you look closely you can see how the tire is almost even... Looks good and doesn't stick out.. but does rub quite a bit.
Old May 3, 2004 | 10:18 PM
TRex's Avatar
I'll add another question. Does anyone have actual experience with improved 60' times ? I am wondering how 315's with sticky street tires would compare to 275 dr's ???
Old May 3, 2004 | 11:42 PM
Eugenio_SS's Avatar
1: Rim dia x width
2: Rim offset
4: Problems
Thanks much!
Dave
  1. 17x11
  2. +50mm offset
  3. YES (front) = 7/32", NO (rear)
  4. a)front wheel got very close to spindle
    b)rear bumpstop interference with wheel
    c)rear tire rubbing
  5. a)grind the little knockle on the spindle (1 min job)
    b)cut the outter half of the bumpstop
    c)BFH massage therapy and adj-phr
  6. pix in signature.
