Offset Help
Old Oct 5, 2013 | 10:11 AM
Rdrace27's Avatar
Default Offset Help
I have a 93 Z28 with Wilwoods front and back. I'm currently running Win wheels but wanted a wider tire in back so I picked up 2 17x11 Torq Thrust 2 46mm offset off craigslist which seem to fit the back. I just bought 2 17x9.5 TT2 46 mm for the front which do not clear the brakes. From my measurements I need about 1/4 inch. The company I got them from said he has a set that are 33 mm offset which should get me 1/2 inch. Does anyone know if this will work? I dont have a problem rolling the fenders but I do not want them out past after I roll them. I also do not want to run a spacer. Any help would be greatly appreciated
Thanks!!
Old Oct 6, 2013 | 11:18 AM
VinR1's Avatar
Yes, you'll be fine
Old Oct 7, 2013 | 09:28 PM
Rdrace27's Avatar
Thanks Vin!!
Old Oct 7, 2013 | 10:23 PM
99Bluz28's Avatar
So are you saying that the TT2s with a +33offset is the same as the +46 but with just a thicker mount pad?
Old Oct 10, 2013 | 12:31 PM
VinR1's Avatar
Not thicker, just closer to the centerline of the wheel
