Will these fit on my 72 camaro :) Help please
I want to make sure these will fit and tuck up before I order. I am lowered 2" all the way around.
Fronts 18 x 8.5 bs is 5.125 offset of +10mm
Rears 18 x 9.5 bs is 5.25 offset of 0
Want to run 275s out back and 245 up front.
Battman do you have a pic of the front? If my offset is 5.125 they will be inboard on the car a little further correct?
Also do your fronts and backs tuck? I am lowered 2"
correct. your setup will protrude inboard about an inch more than my combo (5/8" inch due to BS and maybe 3/8" due to wider the 245 tire). you might have a little rubbing.
my car is also lowered 2". i installed pro-touring f-body springs and leafs. the clearances are pretty tight, but does not rub at all. both front and back tires are inboard of the wheel well lips.
this is the only picture i have available right now. i'll try to take a couple more and post up in the next day or so.
![](http://i143.photobucket.com/albums/r125/cdbattista/1972%20Camaro/P3210011.jpg)
