C5 Z06 Replica Wheel Backspacing Question
I have a set of 17"x9.5" C5 Z06 replica wheels that I am installing on a '69 Camaro. I need to run spacers in order to get a 5.5" backspacing and I'm having trouble trying to figure out what size spacer to run.
The thing I don't understand is that the website shows that they are 9.5" wide, 54mm offset, and a 7.38" Backspacing. How is that possible?
If the wheel is 9.5" wide with a 0"/0mm offset, wouldn't the backspacing be 4.75"?
So if the offset is 54mm/2.125", wouldn't the backspacing be 6.875"? (4.75"+2.125")
I also measured the width of the wheel and it seems like it is actually over 10" in width.
Advertised width measurement it not actually from outer edge to outer edge, it's really from the beads inside. So all wheels will technically be wider than they are advertised as if you measure the entire width.
Sorry can't help with the other questions, but this is common for most if not all wheels.
So 10.5" wide with a 54mm/2.13" offset that would be exactly 7.38" backspacing. (10.5"/2)+2.13"=7.38"
offset is the distance from the hub mounting surface to the actual center of the wheel
if you want to find the actual overall rim width, subtract the offset from the backspacing (converted to mm), and then multiply that by 2, and then convert back to inches.
for your wheels...
backspacing = 7.38 inches = 187.45mm
offset = 54mm
187.45 - 54 = 133.45mm = 5.20 inches
5.2 x 2 = 10.4 inches (overall rim width)
9.5" (rim width between the beads)
Its a lot easier to do this stuff converting everything to metric.
backspacing you need = 5.5 inches = 139.70mm
187.45 - 139.7 = 47.75mm = 1.86 inches
adapter/spacer you need = 47.75mm = 1.86 inches
I highly recommend www.motorsport-tech.com for custom adapters. they'll make one up in that exact size, both hub centric (made to fit snug with the hub mount) and also wheel-centric (to fit snug with the wheels). Essentially none of the cheap spacers/adapters will offer these things for your specific needs, and those universal style adapters are what give people issues. spend the extra money and get the proper stuff!
pic for reference
