New Summit Racing Legend-S series wheels
Has anyone looked at these? I saw these were "New" in the Summit Catalog I received last week and so I went online to take a look at sizing options.
![](http://static.summitracing.com/global/images/prod/mediumlarge/SUM-142-8961GM38_ml.jpg)
I like the 18x9.5 gunmetal set and it has the following specs:
Backspacing (in): 6.750 in.
Offset: +38.00mm
Lug Nut Seat Style: Conical seat - 60 degree
Hub Centric: No
Center Bore Diameter (in): 3.268 in.
Center Bore Diameter (mm): 83.00mm
Wheel Bolt Pattern: 5 x 4 3/4 in.
From some research I did, I believe they should fit, but could someone verify?
Thanks,
Josh
Offset: +38.00mm
Hub Centric: No
Thanks,
Josh
Offset: +38.00mm
Hub Centric: No
Thanks,
Josh
Offset: +38.00mm
Hub Centric: No
Thanks,
Josh
Someone else chime in on this.
LS1Tech Administrator
Received 1,692 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
