drag radials??
Old May 12, 2004 | 01:11 AM
KBoogie's Avatar
Default drag radials??
ok.. how many of you ride around with drag radials on all the time? are they bad in the rain like slicks? How long do they ushually last? i was just currious, becasue wiht my LS1 powered RX7... i have a hard time hooking up... so any input would be preciated it!
Thanx
KB
Old May 12, 2004 | 08:10 AM
frey51's Avatar
I have completely bald comp t/a's. They are great during a dry day, no problem whipping around turns or tearin around town. BUT when it gets wet, beware. Also you do realize that drag radials only last around 4000-5000 miles max. Not really a good investment for a daily type driver if you ask me. I am planning of gettin the gforce kd's because I have heard they stick just as well for a lightly modded ls1 compared to the comp t/a's.
Fry
Old May 12, 2004 | 12:04 PM
KBoogie's Avatar
About how long do they last???
Old May 12, 2004 | 12:43 PM
Tranzor's Avatar
Nittos will last longer than BFGs... you can get a good 10k miles from the Nittos. I've used mine for almost 5k miles now and they still have really good tread with about 30 passes at the track on them.
When they have tread, they handle pretty well in the rain... in fact, they hydroplane less than my Goodyear RSA street tires that came stock on the car do. But when they start to go bald, I wouldn't drive them in the rain anymore.
Old May 12, 2004 | 02:50 PM
KBoogie's Avatar
So think a set of Nitto 555 245/50/16's in the rear would be a good combo for street and track?
KB
Old May 12, 2004 | 03:09 PM
Tranzor's Avatar
KB
That's the size I run and they've worked well for me!
Old May 12, 2004 | 03:51 PM
samz28's Avatar
i rock the 555DR's you must realize due to 100 treadwear they are going to wear out FAST esp with track events. My bro had like 50% wear and hit a puddle and spun off the side of the road. I don't do freeways (city driver) unless necessary, but yeah these ****'s are pretty worn after 5K miles and a 20+ passes. I also rock out at 25psi HOT on the street, say in case i needed to use the extra grip.
Otherwise they kinda suck in winter, its like the tires become hard as a rock on cold mornings.
