do our cars need hub centering rings?
Im putting some 19 inch helo wheels on my car that has a bore size of 74.10. I believe our car has a 70.3 bore size. Will i need centering rings??? I read on some other site that we didnt but i wanted to check here first as usual. That sounds like alot of space
depends
is the bolt pattern sames as ours or is it a bmw one?
if it is same as ours and you sequence and tq the lugs on right
and check it after driving a little, you should be ok.
any case in a nut shell it is like a seat belt
do you need to put it on (besides the law thing)
