Opinions on a new wheel setup.
#41
8-8.5" is WAY too narrow IMO. These cars come stock with 9" wide wheels on the WS6/SS cars, and even those look too narrow (especially with the tucked in offset they have).
Look how good a 17x11 wheel looks and fills out the wheel well:
![](https://i52.photobucket.com/albums/g23/BezersSLPSS/100_3742.jpg)
If you want it to ride and handle atleast half decent then this is as cheap as it gets:
http://www.stranoparts.com/partdetai...D=90&ModelID=7
You'll probably want to add an adjustable PHB if you are planning on running taller or wider wheels than stock.
I won't lie, those wheels do fill the wheel wells very well. In fact I thought those were 18"s to be honest. haha
And really I just want to lower it just a bit. Not for racing reasons, just appearance. Even though right now my ride is terrible due to the 20"s. Didn't SS's come with the option of difference suspension as well? Thought I read that somewhere.. But anyway thanks for the link! These prices are a lot lower than I expected, I thought I'd be spending $1000+.
#43
the avant garde 310's and the 550? I believe look awesome. I think they are silver in color and would accent the stripe on your car well...not to mention they will look great if you choose to get rid of it. Like others have said, run at least a 9.5 inch wide wheels all the way around and if the option is there, run a 10.5 or larger wide wheel in the rear. You will notice a performance gain regardless by ditching those 20's, but I would personally run an 18x9.5 in the front and an 18x10.5 or 11 in the rear. You're on the right track to get rid of the spoiler, put new wheels on the car and lower it. It will be cool to see how this car turns out.
Another wheel that looks like the avant garde is the OE wheel corvette spyder wheel I believe.
http://www.oewheelsllc.com/Wheels_3/...2#.UzlomvldUzY
should fit your budget too. Keep posting pics
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![](http://i58.tinypic.com/knjmu.jpg)
It's actually peeling the paint off with it. So I'll most likely just run a single stripe that runs all the way to the back. Kinda like that one stripe that some camaro guys have that runs in from of the front wheel well all the way to the back. Similar to that.
I do think the setup you said would be a good idea as well. But wouldn't that be expensive? Let alone be harder on the 10 bolt considering I'll be getting more grip?
Some others said not to go with OE wheels because they look cheap/bad, thoughts?
I'll definitely post pictures once she's done with everything, quite excited to see how she turns out, I'll keep you guys tuned in.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#44
I've seen sets of 4 wheels go for $300-800, and wheels/tires go for $800-$2000.
Depends on the style and how motivated the seller is. I've seen shipping from free to $90 to $250, just keep that in mind. And if a tire says it has 65% tread left, that means its about done, don't pay for someone's tires if they aren't any good, or a style of your liking.
#45
But doesn't it get more expensive soon as you get wider and wider when it comes to wheels? The site I used (carID) only offered 18" x 8.5, that was the biggest they offered for 18", however, the 20"s they offered had 9-9.5. I think they had 10 as well.
http://www.discounttiredirect.com/di...e&rd=17&cs=275
http://www.discounttiredirect.com/di...Tires=1&cs=315
#46
I've always wondered how far prices skyrocket when going from 17" to 18". I've done a quick poke around on tirerack. And noticed a slight jump on some tires, but nothing insane...
#47
BMW bolt pattern is 5x120mm, ours is 5x120.65mm. That's less than the width of a mechanical pencil lead. Just make sure you get hub centric rings to center the wheel perfectly.
That price doesn't seem to bad. Do those wheels come in 9.5" width? I would like some wider wheels considering what I learned about the camaro's wheels width in stock form. Hopefully I can find fairly cheap tires as well.
As for tires, what's the minimum amount of tire tread that you think would still be a okay buy?
#48
Yep, hey were 17x9" with 275/40/17 tires all around.
They get more expensive to an extent. 17"s are definitely cheaper than anything bigger, it seems prices sky rocket with anything taller. Check out discounttiredirect.com for pricing: (275s vs 315s)
All depends on style, and especially tire height. Do not go overly low profile, and do not stretch the tires.
SS's and Firehawks could be optioned with SLP bilstiens shocks, 1LE optioned cars got Koni double adjustable's with specific 1LE springs (same height as stock with a higher rate). Both also got different swaybars over the base cars. Fortunately things are pretty cheap with these cars compared to most performance cars out there today.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
So what amount of sidewall would you think be okay with a pair of 18's?
And you aren't kidding about cheap performance parts. Did some more searching on that site. Prices are very reasonable for the amount of performance you gain.
Only problem I see with lowering the car, is the fact I live in POT HOLE heaven.. Also known as Western Pennsylvania.. So with the ground effects on. It'll be very low. Are there any springs that lower .5"? Idk if going any lower would be smart around the pittsburgh area..
#49
That close? Wow, I'll look into them for sure. I have to wait for my tax refund to come so I'll look around.
Newer M series wheels come in wider widths. Just do some homework. Check on ebay even just to get an idea on pricing.
Sidewall height is a factor of wheel width x aspect ratio. A 245/40/18 had less sidewall than a 275/40/18. The first number is the width in mm. The second is the aspect ration (sidewall height, which is width x .40), the last is rim size.
Roughly speaking...
A 245/45/17 is the same height as
A 245/40/18
Or a 245/35/19...
#50
I think 2 or 3/32 is minimum by law. I wouldn't run any less. If a tire stars with 7/32 and someone says it has 50% tread, that means its down close to not passing inspection.
Roughly speaking...
A 245/40/18
Or a 245/35/19...
Roughly speaking...
A 245/40/18
Or a 245/35/19...
Also having trouble finding some rear 18x10 rear wheels of my liking. I would like to avoid staggered but I would like more traction. Just taking in everyones advice.
You think C6 GrandSport wheels would look alright with this car? I kinda like the design. Didn't know if anyone has ran any.
#52
https://ls1tech.com/forums/wheels-ti...port-rims.html
Im not a fan of the styling but to each their own.
#53
I just thought they would look better than your avarage c6 wheels. Never liked them even on corvettes, just bland imo.
Considering they don't look as good, I'll just keep looking. Finding wheels seems a lot harder than I thought. Found some 5 spoke wheels, but kinda want 6 spokes, something different, but not entirely ugly. Haha
#54
They look alright to me. But looks like everyone else hated them. Seems this forum is a hard bunch to please. In fact I found his new setup not that great either. Always liked more wheel than tire look. Small wheels kinda bother me. But as you said to each their own.
Ive always had a soft spot for these wheels since they came out:
http://www.oewheelsllc.com/Wheels_3/...2#.U0HYQlfI7IU
http://www.oewheelsllc.com/Wheels_3/...5#.U0HXp1fI7IU
http://www.oewheelsllc.com/Wheels_3/...2#.U0HXslfI7IU
#55
I know what you are talking about, but IMO thats really hard to pull off with these cars. They generally look better with meaty tires and 17" or 18" wheels rather than taller wheels with shorter sidewalls IMO. Exotics and higher end cars pull it off well, but just not these as much.
I'll take a look at those links if my phone will actually allow me.
#56
Here are some wheel options I'm considering from one site other than the OE wheels I like.
![](http://i59.tinypic.com/wl2jy1.jpg)
![](http://i58.tinypic.com/34qtgs7.jpg)
![](http://i60.tinypic.com/iljcc5.jpg)
What do you guys think? They are all 18's. I didn't see what width they offered or anything. Just want some thoughts on these designs.
#58
I'd definitely stay away from polished wheels. I'm getting rid of mine in teh next few days, I finally decided to go 17s all around and in black so I don't have to work so hard to keep them shining all the time. Especially when I have a black car and that's hard enough work to keep clean as it is! I think 18s in the rear and 17s in the front is the biggest that looks right on these cars. But I think 17's all around is the most sensible for ride quality, handling, looks, etc. just my 2 cents
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#59
Some look like they belong on a ghetto caddi.. :lol
I do agree. A 5 spoke design is hard to beat with these cars. I honestly think the M310's that were posted earlier in this thread look sweet on the car imo. It's different. Only thing that is killing me now is budget..
Also saw another camaro ss locally with the same color on a truck bed at a dealership. Think he might've had 6 or even 7 spoke wheels. They were chrome. Car was really clean. Was going to take a picture lol. Wheels looked pretty good. Of course I saw them as they were driving by so didn't get a good look. Oh well.
But I have considered some C5DD's. But before you said the OE wheels didn't look good. So I searched other sites. But it seems like these wheels are used a lot. But, then again, not many camaro's around my area. But ones I have seem did have 5 spoke wheels. 67Rally posted some good options that I liked as well. Looking or any feedback!
#60
I'd definitely stay away from polished wheels. I'm getting rid of mine in teh next few days, I finally decided to go 17s all around and in black so I don't have to work so hard to keep them shining all the time. Especially when I have a black car and that's hard enough work to keep clean as it is! I think 18s in the rear and 17s in the front is the biggest that looks right on these cars. But I think 17's all around is the most sensible for ride quality, handling, looks, etc. just my 2 cents ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
