Using screws with ET Pro 275 radials
Old Jun 18, 2014 | 03:14 PM
LS1RedZ's Avatar
Default Using screws with ET Pro 275 radials
I've heard different things about this. Who is using screws? I did the high tack thing on mine and they moved about 2" after the first track outing and 4 passes. Now I'm about to swap suspension and it will prolly 60' even harder. Would they be alright to screw since I'm not making a ton of power. Making 875 @ 3700lbs.
Old Jun 19, 2014 | 02:06 PM
funnytruck93's Avatar
Let them slip, or buy beadlocks. radials and screws don't mix. I've seen guys do it and tear up side walls.
Old Jun 19, 2014 | 10:14 PM
HerbCunliffe's Avatar
I was on my way to a bud's house to pick up his X275 Pros. Welp, the screws shredded the sidewalls. I have seen some crazy stuff go down in X275 class with glue but most those guys are on beadlocks now. What rim are you using?
Old Jun 20, 2014 | 11:33 AM
LS1RedZ's Avatar
I have the weld RT's right now.
