Help pick tires
I'm thinking of going with the Comp 2s or the Nitto 555s on my Nissan. The 555s are old, but proven, and the Comp 2s are a step up in every way.
Just going off the tread rating and tread depth I assume the NT05s would hook up and corner better than the MT Street Comps, but the MT's would last longer, ride better, and be quieter.
I will tell you the NT05 are great tires, but they will be bald well before 20k miles. I have no idea on the MTs.
The 555Rs would probably last longer than the NT05. Seriously.
Tire Rack and Toyo themselves list the R1R as an Extreme Performance Summer tire... right there with the Bridgestone RE-11 and Kumho Ecsta XS.
If you look at tirerack test results, while they currently have a best lap time with the new Dunlop Direzza ZII, the Kumho XS is right behind it and it still holds the record for highest lateral G's ever recorded by tirerack. The NT05 do not hold a candle to the Kumho XS on the autox, and you will find many autox guys backing this up if you google Kumho XS vs Nt05.
I appreciate all the input!
I just want to make sure that I get something that hooks up better than my aged BFG KDW's. I am sick of the rear end kicking out in second and when shifting hard into third, with only 350 rwhp. My LCA's do slightly angle down towards the front of the car so maybe that's my problem and I need some relocation brackets.
Now just to decide to get them mounted at the local discount tire for $16/wheel, or a more performance/non-chain shop for $90-150 (for less chance of my rims getting scratched). Also need to decide on alignment specs...
My alignment is:
-1 camber on both sides
Had the caster turned up 4 or 4.5
Toe is right around 0
She is a little happy on the interstate but turn in is awesome.
