Need help quick with AR Rebels
Old May 20, 2004 | 05:46 PM
mr_nate's Avatar
Default Need help quick with AR Rebels
I was told these would not fit on F-body's, but it seems as if they should... heres the specs..
American Racing Rebels, 18x10
Offset: 41
Backside: 7 1/8
Bolt Spacing: 5x4 3/4
Let me know ASAP! I am in the process of ordering them...
Here's a picture of them:
http://www.americanracing.com/images.../mega/m699.jpg
Other info is here: http://www.americanracing.com/wheels...lloy&section=P
Thanks!
-Nate
Edit: It would be 18x10's w/ the 41mm offset on all 4's
Old May 20, 2004 | 06:37 PM
Scalpel's Avatar
Bolt spacing is wrong isn't it?
Old May 20, 2004 | 06:43 PM
mr_nate's Avatar
Is it 3/4 or 1/2 for F-bods? I can't remember. If it is 1/2, I'm not sure if the 30mm offset would work...Damn, I'm confused..
Old May 21, 2004 | 09:33 AM
Xsta Z 28's Avatar
30 mm will not work. 41 mm will work in the back, but are questionable up front with a 10" wheel. The bolt spacing on a F-Body is 4.75"
I am comparing these wheels to mine. I have 18" x 9.5" up front with a 38 mm offset. it will be close but could work.
Old May 21, 2004 | 10:39 AM
black_z's Avatar
DO you think AR would be willing to custom make these in a different offset? I would love some 17X10's all around with the correct offset.
Old May 21, 2004 | 02:09 PM
mr_nate's Avatar
I dont know if i want to risk it, maybe I should buy a set of ZR1's and let someone else be the test subject..
Old May 21, 2004 | 05:43 PM
Ferocity02's Avatar
Those are badass rims and would sure like to see them on F-bodies some day. They are pretty cheap too
Old May 21, 2004 | 10:29 PM
SMDLS1's Avatar
Default fit
they fit, they have a guy here in town with 18" all around looks real nice.
Old May 22, 2004 | 02:12 AM
mr_nate's Avatar
Awesome, thank you so much! Time to order
