Offset Question!
Old Mar 13, 2015 | 08:16 PM
L3THAL_Z28's Avatar
Arrow Offset Question!
I probably should have asked this question before I put my order in 30 min ago but might as well ask it anyway since they are being custom built and can probably still make changes, anyway...
I have 57mm offset on my wheels and I hate the way they tuck up. I've read on here that 40mm usually sits flush with the fenders on a Camaro. So I ordered wheel and hub centric wheel adapters 3/4" thick (19mm). 19mm wheel adapters would put me at a 38mm offset correct?
On a 4th Gen Camaro will the wheels stick out a bit or will they more or less still be flush with the fenders? Should I have gone with a 17mm spacer instead? Any input is greatly appreciated.
Btw I've read the sticky that says 18x9.5 wheels will fit on a Camaro with Offsets of 38 to 56mm. I'm just making sure with my wheels that offset of 38mm won't stick out.
Old Mar 14, 2015 | 10:52 AM
L3THAL_Z28's Avatar
Nobody has a clue?
Old Mar 29, 2015 | 04:12 PM
2MCHPWR's Avatar
sorry i don't know but can you post pics of your wheels? I'm curious how 57mm looks front and back.
Old Mar 29, 2015 | 11:47 PM
Kory's Avatar
38mm offset with 9.5 wheels should sit flush with the fenders
Check out the pictures of this camaro with 9.5 38mm fronts
https://ls1tech.com/forums/wheels-ti...fset-kdws.html
Old Mar 30, 2015 | 12:56 PM
L3THAL_Z28's Avatar
I'll post pics when I get a chance
L3THAL_Z28's Avatar
Cool, thanks for the link. That's exactly what I'm looking for, a flush look with the fender.
