Wheel spacers or adapters?
Old Mar 24, 2015 | 08:30 AM
mcalus's Avatar
Default Wheel spacers or adapters?
I have a pair of widened 10 spokes that I had on my 93. I had to bfh the wheel wells. I don't want to for my new 02 SOM I just picked up. I really only need 1/2" on each side. What are my options?
Thanks!!
Old Mar 24, 2015 | 10:51 AM
Midnight02's Avatar
Couple options:
The best looking option is probably a 1/2" spacer and longer studs.
The "easy" route would be a hubcentric adapter. The rub here is that the smallest adapter you can usually find is 1" and if the back of your wheels are solid (instead of recessed), you'll need a 1.5" thick spacer to clear the factory studs. My 18" x 10.5" C6 wheels are recessed so I run a 1" adapter in the rear. My track wheels are OEM C5 Z06 Alcoas -- they are solid in the back and it takes the 1.5" spacer to mount properly.
Old Mar 24, 2015 | 11:23 AM
thunderstruck507's Avatar
1/2" spacer and if you intend the setup to be relatively permanent you can have the spacer tig tick welded to the wheel so it's simple to install and remove the wheel
I just bought some cast aluminum 1/2" spacers on ebay for $13 shipped.
Old Mar 24, 2015 | 12:07 PM
mcalus's Avatar
Do you guys have any links? Also what length studs would I need? Both axles need to be pulled to install new studs right?
Old Apr 2, 2015 | 10:42 PM
silverWS.6's Avatar
Following this one, I want to do this also for all four corners
Old Oct 29, 2015 | 12:17 PM
ColeJJones's Avatar
Originally Posted by Midnight02
Couple options:
Thank you! The search requires alot of **** to siff through. I can see why anyone would start a new thread just to ask a simple question.
Old Oct 29, 2015 | 02:40 PM
LS1-450's Avatar
If you're asking about rear only & for mostly straight line driving, then OK. Front wheels that turn are a different issue. Spacers change the king pin inclination angle & will most certainly negatively effect steering.
Old Oct 31, 2015 | 06:26 PM
2JAWZ's Avatar
You do not need to pull the axles to change wheel studs*
Old Oct 31, 2015 | 08:41 PM
mcalus's Avatar
Although I sold my car so It doesn't make much of a difference but for information purposes, I'm pretty sure you can't get the longer studs in without hitting the backing plate, no?
Old Nov 1, 2015 | 03:58 AM
2JAWZ's Avatar
Didn't take that into account,, so not 100% sure on that one. I have never used longer studs*
Old Nov 1, 2015 | 06:28 AM
unioncarpenter84's Avatar
i recommend using arp studs. They have a package for our cars. I have the front arp 2.5 inch long studs with the 15mm spacer from eibach
And on the rear i have 1 inch hubacentric spacers in the rear
