Drag Tires for 15x10 and 15x4
What size tires is recommended for a drag setup for a 99 TA with 3.73 A4 and a 10 bolt. The rims I bought are 15x10 rear and 15x4 front weld racing rts I was leaning towards a 26" or a 28" tire for the rear the car sees frequent 1/8 mile drag strip use and occasionally 1/4 mile I have regular tires and rims for every day car is my summer DD. thanks for your support.
I'd run the lightest setup you could. With the 373's you don't need a 28" tire killing your gear and weighing you down. A 275/50 Hoosier drag radial would work just fine, they are considerably lighter than the mickeys. I'd also run a bias front like a DS2, just don't get caught in the rain with them. This is the exact setup I'm going to run with rts's.
