GoodYear Eagle F1 GS-D3
Otherwise, they were great tires until temps got down below about 40-45°F or so, and then they'd spin like I was on ice.
Rather than "toss um" why not offer them up for sale? Someone should be interested. If you just bought them new via a tire store they often allow 100% exchanges towards another set of tires. If they're from Tire Rack don't know what their policy is. When I just did tires for my car I got the best prices from local dealers and on-line stores. Took that best price to Town Fair Tire which advertises to beat any legitimate price. And they do have a 30 day exchange policy if you don't like them. As I see it, the bigger tire stores should be able to match the on-line sellers and give you some type of reasonable exchange/warranty if the tires just aren't right for your car.
I've never quite experienced anything like this with car tires, they are LOUD that is the only way to describe them. They also rubble at low speed depending on the road surface to the point of distracting you. I have a Flowmaster exhaust, you can not hear the exhaust over the tires. The tires are louder, how can this be? I'm still like WTH?
I think part of the shock is the Nexen tires were perfect, Car handled great and no tire noise at all. No pulling to every little groove, there is a stretch of highway near here that was repaved with small grooves. The Goodyears walk all over that highway and you can't predict it. You can't believe how bad it handles doing a lane change, It actually goes out of control completely as you come over the line in the road then comes back until the other tire rolls across then it does it again. You lose all feeling of control and kind of panic trying to feel how to stop the car from veering back into the lane you were in. I'm not exaggerating.
Suprisingly, I don't see many references to them being overly noisy, though enough do mention it, especially after the tires have from 3,000-10,000 miles on them (your 50% tread left is at that range). Some comments on cupping for tires that were off the car for a while. Many compliments on superb wet traction. A numer of comments on the "pulling" when following road grooves. It is mentioned that sometimes they might be hard to balance. In that case, the tires will never sound smooth. Generally, decent reviews though....but enough lousy ones to give you some caution...especially for the price. One thing I've gotten from reading hundreds of reviews on different tires is that there will always be those where they don't feel or sound right.
http://www.tirerack.com/survey/Surve...agle+F1+GS-D3#
http://www.tirerack.com/tires/survey...y.jsp?type=UHP
http://www.tirerack.com/tires/survey...ay.jsp?type=MP
Check the actual build dates on these, since they could be VERY old, and that would cause them to harden, and possibly give more road noise/vibrations, as well as MUCH less traction than a fresh, newer build date tire.
They are also INSANLY LOUD, I can not hear the exhaust and to listen to the radio you need to crank it up good.
On a separate note the installer damaged the rim edges with the tire machine..........all 4 rims now have a 2 6 inch long gashes on the face of the edges. I took it back to show him and he said "don't worry I'll take care of you" <what ever that means but he is my regular place for inspections etc so maybe he'll discount something next time. He was nice about and acknowledged his machine did it. Told me the part that runs along the rim broke today when he tried to use it. Eff it the car is almost 15 years old.
I should have tossed these dam tires in the 1st place but its my wifes car and she loves the way the tires look. They were a sob to get off and on the rims both times.
As mentioned above, you might be confusing these with the OE tires issued on WS6/SS cars, which were the older F1 GS (not D3) with a very different tread pattern. These were in fact discontinued many years ago, and were a vastly inferior summer performance tire as compared to the D3. The only upside to the older F1 GS was better cold weather performance, but at the expense of premium summer traction.
EDIT:
It just occurred to me that you might be referring to the 245/50/16 size having been discontinued in the GS-D3s. I do believe that happened a few years back, so you would be correct. However the 275/40/17 and 285/40/17 sizes are still in recent production.
I looked at the tires closely and it seems the out side edges of all the tires have a odd cupping to them. Bet that's the noise I'm hearing, I have them@33psi I'm going to put 36 in and see if it helps the noise.
I also notice these tires allow you drive the car to its limits. Where the Nexen n7000's that were on are quiet and well behaving they don't have raw edge these do.
I pulled away from a stop light HARD in the rain down into 2 sweeper turns without any sliding or spinning, pretty amazing. Well over the posted 55 speed limit.
EDIT:
I AM speaking of the D3s, and YES, I know that the non-SS/WS6 OEM, 245/50-16 size has been gone for about 6-7 years now, as I was looking to get some of them about that long ago.
IF I stick with this size wheel/tire (16x8/255/50-16), I may even go to a set of the 100 tread wear, semi-R compound road race/autocross donuts for my next summer only set (Toyo R888/RA-1, Nitto NT-01).
I thought that the 275 and 285/40-17s were also long gone, but I guess I was wrong.
