which welds fit without grinding calipers
Old Jun 3, 2004 | 05:57 PM
jruss's Avatar
Default which welds fit without grinding calipers
I need to know this and if you have to use spacers etc. grinding the calipers is out of the question for me thanks
Old Jun 3, 2004 | 07:10 PM
NumberOneSled's Avatar
If you go with 15" welds then you have to grind.
Old Jun 3, 2004 | 07:20 PM
WildBills Toyota's Avatar
If you get spacers you will be fine. I run my skinnies with spacers.
Old Jun 3, 2004 | 09:33 PM
Fast SS on TNT's Avatar
Please tell me that you also use an extended stud with spacers up front.....otherwise you have less then 5 turns on the lug nut, and are inviting serious injury and death.
If you don't want to grind the **** out of your calipers, spend the dough on a set of Bogarts.
Old Jun 3, 2004 | 10:04 PM
boomcase's Avatar
I know they are not welds , but No grinding or spacers. centerline convo pros, 15 by 4 and 15 by 7.5 with 5 inch back spacing , check pic.
Old Jun 4, 2004 | 12:11 AM
They are just small spacers and they went on plenty tight. I got lots of turns out of them
Old Jun 4, 2004 | 08:37 AM
Steve Burger's Avatar
LS1TECH Sponsor
ARP extended studs are cheap and easy to install. I would get them. I have them on all 4 corners. It's a safety thing.
Old Jun 4, 2004 | 09:44 AM
Derek98z's Avatar
Still have to grind the rears regardless.
Old Jun 4, 2004 | 09:51 AM
NOZR1's Avatar
Do you have a part #?
Old Jun 4, 2004 | 08:26 PM
koolrayz's Avatar
can you use the 10.5x28 et drags on the 7.5" rims
Old Jun 4, 2004 | 09:09 PM
ya, I was just talking about the front
Old Jun 5, 2004 | 12:07 PM
LS1TECH Sponsor
No I do not have the part numbers. Many of the sponsors carry these as well as Jegs and Summit. They are 12mm studs and are much longer than stock. I got mine from Billingsly.
Old Jun 5, 2004 | 12:50 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Okay...
Front:
15x3.5 Weld, 5/16 spacer, no grinding
Rear:
16x8, 16x9 Weld XP, no spacer, no grinding (but these rimes are 22-23 lbs)
no 15" weld product will fit in back with out at least some grinding
Old Jun 7, 2004 | 05:14 PM
DONAIMIAN's Avatar
Prostar XP's all the way
Old Jun 7, 2004 | 06:30 PM
02WHITEZ's Avatar
what size 16 x 8 or 16 x 8.5
Old Jun 8, 2004 | 10:34 AM
LS1Tech Co-Founder
I had:
16x8 Draglite XP
16x9 Draglite XP
Old Jun 8, 2004 | 02:11 PM
02WHITEZ's Avatar
what about prostar xp's 8's or 8.5's
Old Jun 22, 2004 | 09:49 PM
Special K '01 WS6's Avatar
my draglite XP's hit the calibers in the back... 16x8
Old Jun 22, 2004 | 10:15 PM
02WHITEZ's Avatar
so the prostar xp's 16 x8 's will fit perfectly all the way around like my stock wheels?
Old Jun 23, 2004 | 02:16 AM
i don't know about the pro stars... everyone says the draglite XP's should fit without grinding... i don't know why mine don't??
