15x3.5 or 15x4 skinnies w/ clearance to run stock length wheel studs??
I'm trying to research to see if there are any specific brands of skinnies that will fit with enough clearance to use stock wheel stud length? I know a lot require spacers and new wheel studs, but I'm trying to avoid that since I want to run my normal 18" chrome c6 z06 rims for daily driving without wheel studs sticking out excessively. I apologize if this could have been found in search, but I wasn't getting any solid answers. So if possible skinny size and brand that doesn't require spaces or can be used with stock length studs. I appreciate any input, info, or pictures. I will grind calipers if needed. Thanks!
The Jegs or Summit cheap cast aluminum 15x4" wheels will fit with stock wheel studs, but calipers with have to be ground down a bit.
Here's a pretty old picture of my car with stock studs and Summit star wheels
