Aftermarket 19in C4 ZR1 rims
Whats going on guys? I've recently come across a set of 19in aftermarket (different style) rims online that were originally made to fit a C4 ZR1. The sizing is different though than the original stock size. Assuming the information i've received is correct they are 19 x 10.5 front with 57mm offset and 19 x 11.5 rear with 57mm offset. Any ideas if they would fit an 02 WS6? I don't mind doing a little work to make them fit, actually i expect it on the rears, but i don't want to do minitubs to make them work. I plan on putting a set of coil overs on eventually but currently its stock height. Any info is appreciated!
