17" 9.5?
Old Aug 14, 2015 | 10:01 PM
icor1031's Avatar
Default 17" 9.5?
Anyone know of any decent 17x9.5 wheels with a price comparable to used WS6 wheels?
Or better, staggered 17x8.5 & 17x9.5.
(WS6 wheels are only 9", hence my question.)
Old Aug 15, 2015 | 10:13 AM
JD_AMG's Avatar
Have you looked at http://www.oewheelsllc.com?
http://www.oewheelsllc.com/Wheels_3/...4#.Vc9U_5ec7IU
http://www.oewheelsllc.com/Wheels_3/...s#.Vc9VlJec7IU
http://www.oewheelsllc.com/Wheels_3/...1#.Vc9Vvpec7IU
http://www.oewheelsllc.com/Wheels_3/...T#.Vc9V15ec7IU
Have you tried looking at tirerack or other places as well?
http://www.tirerack.com/wheels/resul...&package=false
Also don't bother staggering the wheels, just get 17x9.5" all around, it will look better than a skinnier 8.5" front wheel and that way you can rotate tires too. If you want a staggered, aggressive look get a 10.5" or 11" rear wheel with a 315 tire out back, and at least a 9" wide wheel in the front. < NOTE this is not ideal for handling if that matters to you.
Old Aug 15, 2015 | 12:50 PM
icor1031's Avatar
I did see tirerack, I hated their wheels.
I found oe after making this post.
I wanted to do staggered 245 + 275, for handling and understeer... is this a bad idea for any reason other than it doesn't look as aggressive / can't rotate front-rear?
(245 won't follow ruts as much)
Old Aug 15, 2015 | 04:09 PM
JD_AMG's Avatar
You want understeer vs being neutral???
275s out front will handle way better, and will give neutral handling with 275s out back (all else equal).
As far following ruts, a wider tire will follow more ruts, however good shocks with help counter it as well as a good (not stock) alignment.
